What causes a working RB600 to lose license?
What can cause a 100% working RB600 to lose license, and when connected to console say Demo License has expired and then reboot.
The Router is connected to UPS so not voltage issue, and there was no bad weather.
It was online, and then the next went into reboot loop.
I can’t re-install the router, because LAN1 has not been working.
Really confused as to why the rb600 that was working suddenly does this, with absolutely no changes to the system whatsoever.
I probably could get the router RB600 working if there was an alternative way to re-install other than netboot from ether1.
I tried putting the npk files on cf card and that doesn’t work.
Between the versions license formats changed. You did not read the upgrade notes and didn’t upgrade the license before upgrading. Go back to a working version, follow the license upgrade instructions on the download page, and then upgrade.
As I said, it was a working system with ROS3.30 no changes were made to the system (uptime: 300+ days)
Can’t do a re-install Ether1 does not work from some reason. It’s basically been bricked
Runs on UPS so power is not the reason and no weather when the problem occurred.
Very weird.
I misunderstood.
Contact support@mikrotik.com. If the NAND got corrupted the community can’t help you.
