hi everybody
i am facing a problem. a site with 433ah with three in one :
three sector is connected to that and arount 15 to 20 customer on that radio.
the problem is all customer are not getting the full speed and time=ms is breaking,
and every time i change the frequency and band.
some body help me ?
use the queues option this will solve the problem.
how to configure the queue option ???
currently rb433 is configured access point (bridged )
can i configure routing. is it good than briged network
mode =ap
freq 2447
band= b+g
and all customer are connected with diff diff speed
plz tell me how to configure queues option ?
there is no nat or dhcp configured on the router. it simple access point.
client uses static ip provided by us..
please mail me your network scnario . on my mail id imran_cool024@yahoo.com
just add the ip in queues option and rember to select the interface for that ip . if you forget to select the interface than it will create trouble for you . after you add the quese give tham the specified speed in max speed and min speed . than we we run script in terminal the command is interface bridge setting set use-ip-firewall=yes after this only your quese will start working . gave what speed you wann to customer from your server. but actual speed will be manage by your router
Imran Khan
d’t forget to give karma
hi imran
i am trying to configure queue but not done ???
can you help me to do this …
