What Devices
hi there,
we have to build a new wireless network I was thinking of using 2 RBMETALG-52SHPACN devices, one connects into the main router and acts as an Access Point and then the 2nd RBMETAL is further away and acts as a Repeater and Access Point is the RBMETALG-52SHPACN capable of doing this, bear in mind the 2nd RBMetal has to act as both repeater and AP, also the devices are outdoors or do i need one with 2 radios, if so what product do i need?
thanks
Jamie
You can use that, it should work, but If you want to create a good service, you need to use something as “station” to receive signal and repeat in another frequency with that Aps.
I prefer to have devices for point to point and devices for multipoint. And try to avoid APs with 2 radios in same frequency.
