connection-limit=!30,32
- Will above be TRUE for any number of connections except 30 or less than 31?
- Is mask applied on source or destination address?
- are new, established, invalid, related connections counted together?
thanks!
thanks!
Ok so I run some tests and found the answer for
still I’m not sure how ROS is counting the connections. Does anybody know?
It’s called connection tracking.
/ip firewall connection print
Does connection-limit include half closed connections in the count?
