I’m wanting to test a subscribers PPPoE connection (with a public IP address) using torch as they are saying it will not work with IP Sec. When ever I look at the traffic on the connection it looks like ordinary web / POP3 traffic. What do I look for to see if the link is passing IP Sec?
I don’t use tourch that much… I can’t see given the propper filters are set, why it won’t show up however… You may not be able to see the contents of the packets as it will be encrypted, but the packets itself should definately show up.
tcpdump that I always use, has no problem what so ever to show these packets and protocol.
TCP ports 50 & 51 are not IPSEC. GRE is used by PPTP and not IPSEC.
You’ll rarely see ESP and AH on the link as most clients will be using NAT traversal mechanisms. These encapsulate the ESP and AH into TCP and UDP data streams. These can use various port numbers including UDP:4500 & TCP:10000
Thanks Andrew, so basically it could be hard to spot. There sould be no reason it will not run inside a PPPoE tunnel is there? there is no NAT going on as I’ve supplied the customer with a public IP address.
