What does rip do?
Does eoip and rip work the same way? If i use rip will each user need their own ip range? And will they be able to connect to each other?
I have founf a tutorial on how to setup rip on client but how do i set it up on the access point?
I cannot use eoip anyone becos there is non-mikrotik clients here
RIP is a routing protocol used to enable routers to talk to one another and exchange routing information. EoIP is a tunneling protocol. The two do completely different things.
Ok thanx, what can i use so that mikrotik and non-mikrotik routers and users can connect to each other and share data? At the moment im using eoip which put everyone on one iprange
