What download/upload can I get having such parameters.
I followed all LHGG installation manuals and I successfully connected via LTE.
I’m getting the following reception parameters:
manufacturer: “MikroTik”
model: “R11e-LTE6”
revision: R11e-LTE6_V025
current-operator: T-Mobile #5GBardziej
lac: 53178
current-cellid: 33573151
enb-id: 131145
sector-id: 31
phy-cellid: 489
access-technology: LTE (CA2)
session-uptime: 42s
primary-band: B7@15Mhz earfcn: 3175 phy-cellid: 489
ca-band: B3@10Mhz earfcn: 1599 phy-cellid: 489
rsrp: -69dBm
rsrq: -11dB
sinr: 16dB
ri: 1
Question: what are the download/upload parameters Imay achieve in such location?
Thaanks
M.
Signal strength and quality are good, there’s CA available. If you were the only user in these two cells, you could get something like 150/35 Mbps (R11e-LTE6 doesn’t do CA in uplink). Actual performance will very much depend on cell load which varies with time of day and is usually the worst during evening and the best in small hours.
