What happened to Nth in Beta?
I’m trying to use this example on a router that I’ve migrated from 2.9.42 to 3.0 Beta 7:
Improved Load Balancing over Multiple Gateways
http://wiki.mikrotik.com/wiki/Load_Balancing
The symptoms of the problem is that the first Nth does not mangle any more.
The most obvious difference between 2.9.42 and 3.0 Beta 7 is that Nth now has less fields.
In 2.9.42:
  • Every
  • Counter
  • Packet
In 3.0 Beta 7
  • Every
  • Packet
Is there some advice for me?
This is very simple. There are no more counters. For example to mark every second packet:
chain=prerouting nth=2,1 action=mark-packet new-packet-mark=odd
     passthrough=yes;
chain=prerouting nth=2,2 action=mark-packet new-packet-mark=even
     passthrough=yes;
It is very important to set passthrough=yes, otherwise nth won’t work correctly.
Thank you.
Just for reference the old (pre-version 3) example on the WIKI looks like:
/ip firewall mangle
add chain=prerouting in-interface=Local connection-state=new nth=1,1,0 \
    action=mark-connection new-connection-mark=odd passthrough=yes comment="" \
    disabled=no
add chain=prerouting in-interface=Local connection-mark=odd action=mark-routing \
    new-routing-mark=odd passthrough=no comment="" disabled=no
add chain=prerouting in-interface=Local connection-state=new nth=1,1,1 \
    action=mark-connection new-connection-mark=even passthrough=yes comment="" \
    disabled=no
add chain=prerouting in-interface=Local connection-mark=even action=mark-routing \
    new-routing-mark=even passthrough=no comment="" disabled=no
