what happened to pptp and l2tp
I’ve just dug up some old RB112 and intended to use it as a secure gateway to a network.
I’ve upgraded from 3.20 to 5.14 (with license update in meantime) and tried to configure either pptp server or lt2p (ipsec) server but in interface menu there are no pptp or l2tp submenus.
In one of my 112’s with 3.14 those menus are available.
Can someone tell me what happened to pptp and l2tp and how to re-enable it?
RB112 lv4
when you upgraded, ensure you installed/activated the ppp and security packages. check under /system packages print for the status of them
Thanks, ppp package has been disabled during upgrade, after I’ve enabled it everything works just fine.
