What happened with topic Mikrotik User Manager (beta)??
The topic does not exist anymore :S
here it is again :slight_smile:
:smiley:
http://userman.mt.lv/userman
(Username:password)=demo:demo
Any news about the manager?
Regards
:unamused: No news :cry:
what news do you want? it’s being made. do you have any suggestions for improvements?
some..
  1. When the user almost reach the time limit, send an e-mail to the user.
  2. The option to add the company logo and some other data.
  3. The option to translate the user front-end (for checking time, volume balance, ect).
  4. If it´s posible to show a pop-up when the user logs in (via pppoe).
  5. Option to block an user and to show a billing page (customized) when the user logs in.
  6. An option to create packages based on time periods (half day, night) so the user could only use his 50 hours only by the night or by the day, ect.
  7. Diferent access groups, so an employee can only add o view some items of the radius.
  8. On user parameters, option to add a dynamic chain on MT firewall, or an option to add diferent kinds of services (http, all, pop3 smtp, ect).
  9. Reports by total daily traffic, user daily traffic.
  10. Reports of total payments by user.
  11. In user front-end, option to change the password, request more time-data.
  12. In user, option to set his MAC address.
  13. Option to create advertisements pop-ups (if it´s posible…).
  14. Exporting to pdf or xls the reports, the user list, etc.
  15. Backup and restore the configuration.
  16. Option to set the user limit-at, max-limit, burst, queue priority and parent queue.
  17. In user options add total limit value (up+down).
    Regards
Normis, will some of the suggestions be added to the userman?
Regards
I have a suggestion… A US based server so it doesn’t take 5 minutes for the page to load when trying to enter in data! :slight_smile:
C:\Documents and Settings\Administrator>ping moon.mt.lv -t
Pinging moon.mt.lv [159.148.147.194] with 32 bytes of data:
Reply from 159.148.147.194: bytes=32 time=192ms TTL=42
Reply from 159.148.147.194: bytes=32 time=203ms TTL=42
Request timed out.
Reply from 159.148.147.194: bytes=32 time=193ms TTL=42
Reply from 159.148.147.194: bytes=32 time=195ms TTL=42
Reply from 159.148.147.194: bytes=32 time=191ms TTL=42
Reply from 159.148.147.194: bytes=32 time=197ms TTL=42
Reply from 159.148.147.194: bytes=32 time=194ms TTL=42
Ping statistics for 159.148.147.194:
    Packets: Sent = 16, Received = 15, Lost = 1 (6% loss),
Approximate round trip times in milli-seconds:
    Minimum = 191ms, Maximum = 203ms, Average = 194ms
Control-C
^C
Anyway we can improve this? :slight_smile: I’d love to start using this service if it were more responsive.
i already sait that the userman will not be based anywhere. it will be a package for RouterOS
Oh maybe I’m mistaken I was refering to the hotspot manager - http://moon.mt.lv/radius
Or is this a beta test for the RADIUS server you eluded to in other posts?
that project has been replaced by the user manager.
this will be a package on routeros and has more features than the old hotspot manager
  • option to set hostname for user to produce DNS entry when he gets IP to allow user to be accessibel not just by an IP but memonic address
  • options to add custom fields for users
  • option to access user database from outside, to allow using it for custom applications
  • option to add user’s IP to specific Address list
  • option to create simple queue (even if usermanager is used just to set ip address to user) and set all properties of simple queue
doesn’t work in Safari Version 2.0.3 (417.9.2) Mac OS X 10.4.6 PPC :frowning:
You can login and the left hand frame (with the menu) loads but the right hand frame never loads. Clicking any of the buttons (except logout) has no effect.
now only if we had a mac here :frowning: we will try to do something, sorry for the problem.
Do you have a date you are expecting to release the mikrotik radius server?
I need it urgently and don’t want to waste time setting up and learning freeradius if Mt’s is due soon.
a few weeks (maybe at the mum…)
Hi there,
Will the User manager have the ability to control PPPoE clients useage based on data not time connected. Say 256K up and down untill they reach total data of 1gb for that month cycle, then either disconnect them or slow them to a lesser throttled speed say 64k up and down. Email notification would also be good
Cheers.
Yes, such feature is on the to-do list.
