What happens when i set rate-set=configured on station ?
when i set rate-set=configured on station, and I set some supported rate for A and some supported mcs for N, i see that they seems have no effects, and the maximum modulation reached is the one sets by the supported-rate on the AP side.
Is this correct? Is there way to set a lowest modulation on a single station? (ex. when I have a statation that has not very good signal)
SOLVED … Using nv2 the AP is responsibile for the modulation and the settings doesnt take effect on station side.
