what i do wrong
hi, im trying simple script but cant get it working
:local txbyte
:set txbyte [ /interface ethernet get value-name=driver-tx-byte ether1]
:if ($txbyte > 50000) do =
/interface ethernet reset-counters ether1
Script Error: cannot compare if nothing is more than time interval
i checked varible by :put $txbyte the :set is working fine problem in IF statement, so can anyone plz tell me what i did wrong?
Some investigation shows that the output of your command do have spaces.
“1234” bytes shows as “1 234”
http://forum.mikrotik.com/t/tx-bytes-rx-bytes-have-spaces-and-are-unusable-please-help-edited-and-added-more-info/109490/1
I have cleaned up the script in that thread some. Cut and past this to command line. (to create a function)
:global removeSpace do={
	:local temp
	:for i from=0 to=([:len $t] - 1) do={
		:local char [:pick $t $i]
		:if ($char = " ") do={
			:set $char ""
		:set temp ($temp . $char)
	:return $temp
Then change your script to some like this:
:local txbyte
:set txbyte [$removeSpace t=[:tostr [/interface ethernet get ether1 value-name=driver-rx-byte ]]]
:if ($txbyte > 50000) do={
thanks for your help, but i did not get your code runing, i fix it by
:local removeSpace do={ :local temp;
    :for i from=0 to=([:len $t] - 1) do={ :local char [:pick $t $i];
        :if ($char = " ") do={ :set $char ""; }
        :set temp ($temp . $char); }
    :return $temp; }
:put [$removeSpace t=[:tostr [/interface ethernet get value-name=driver-tx-byte ether1]]]
:local txbyte
:set txbyte [$removeSpace t=[:tostr [/interface ethernet get value-name=driver-tx-byte ether1]]]
:put [/interface ethernet get value-name=driver-tx-byte ether1]
works like charm , ty
