hi all my problem in my proxy-test cach when i make eanble cach the cpu load becom 80% ~ 100% and many time out in dns ping so browsing is slow.my cpu is 1700 half cach and ram 256 with only 40 users online plz thanx for help
same problem
we need help
if you want to make proxy, just make sure that u have a enough memory and HD space. just want to remember that 1Gigabyte for space HD use 15 RAM + 55 RAM for default, so just check again your config of your proxy
Which version do you use and which proxy package ?
this is very abnormal issue…have you applied proper access rule for proxy? any abnormal traffic? it could be reason if your proxy is being used as free proxy.
regds,
Asad
thanx for reply
i used only 3 g to web proxy test cach.2.9.27 and cach used from my users only thanks ![]()
