Hello
is rb133 more reliable than the rb153 with 3 wireless cards?
Hello
I don’t think there is much difference, they are the same platform and CPU, just different number of interfaces
id say the more things that you use on the routerboard as in services and or cards the more unstable either will be, so if you use the one that has more interfaces and you put more services on it then the one that is being used more could be a lil less stable as in cpu usage/ memory/ hdspace will go up
