what is my problem
hi guys
i have this problem
i use MT two weaks ago
i use this configurartion
hotspot
[admin@MikroTik] ip hotspot> print
Flags: X - disabled, I - invalid, S - HTTPS
NAME INTERFACE ADDRESS-POOL PROFILE IDLE-TIMEOUT
0 X hotspot1 ether1 dhcp_pool1 hsprof1 10m
webproxy
[admin@MikroTik] ip proxy> print
enabled: yes
src-address: 0.0.0.0
port: 8080
parent-proxy: 0.0.0.0:0
cache-drive: system
cache-administrator: "webmaster"
max-disk-cache-size: 34571000KiB
max-ram-cache-size: 159000KiB
cache-only-on-disk: yes
maximal-client-connections: 1000
maximal-server-connections: 1000
max-object-size: 15000KiB
max-fresh-time: 3d
the pc have 1700 cpu , 256mb ram and 40 gb HD
the problem is every 10 min. the internet does down for one min.
and go back to work fine
when i disable hotspot its work fine with no disconnect the internet
sorry for my bad english
thanx for everyone
help plz :question:
Current configuration export does not have enabled HotSpot.
Which version do you use for RouterOS and proxy ?
sorry for that …
but i disable it because if i enable it (every 10 min. , dns requset time out)
