What is order of processing mangle?
I have 2 rules in mangle:
one that sends 2 ports of same ip over first wan and second mangle rule which sends all ports over second wan.
But the rule with two ports dont work, independent of that: the rule with 2 ports is on first place in mangle list. Why?
Passthru enabled?
Maybe the conditions aren’t matching? Do its bytes/packets counters increase? can you paste /ip firewall mangle export here?
The rules are 1,2,3..for example from up to down in mangle
What I am asking is if they are processed from up to down, like 1>2>3 or not?
Yes, top to down order.
