What is OSPF ABR?
My topo:
Ros-1<–>Ros-2
Ros-2<–>Ros-3
Ros-3<–>Ros-1
all of them is OSPF neighbor and state=“Full”
In Ros-1 have an loopback0(IP is 10.10.10.10/32)
and it has been network in Area12
R1:
[admin@Ros-1] > export
add name=loopback0
/routing ospf area
add area-id=0.0.0.12 name=A12
add area-id=0.0.0.13 name=A13
/routing ospf instance
set [ find default=yes ] router-id=1.1.1.1
add address=10.1.12.1/24 interface=ether1 network=10.1.12.0
add address=10.1.13.1/24 interface=ether2 network=10.1.13.0
add address=10.10.10.10 interface=loopback0 network=10.10.10.10
/routing ospf network
add area=A12 network=10.1.12.0/24
add area=A13 network=10.1.13.0/24
add area=A12 network=10.10.10.10/32
/system identity
set name=Ros-1
R2:
[admin@Ros-2] >  export
/routing ospf area
set [ find default=yes ] router-id=2.2.2.2
add address=10.1.12.2/24 interface=ether1 network=10.1.12.0
add address=10.1.23.2/24 interface=ether2 network=10.1.23.0
add area=backbone network=10.1.23.0/24
/system identity
set name=Ros-2
R3:
[admin@Ros-3] > export
/routing ospf area
set [ find default=yes ] router-id=3.3.3.3
add address=10.1.23.3/24 interface=ether2 network=10.1.23.0
add address=10.1.13.3/24 interface=ether1 network=10.1.13.0
/system identity
set name=Ros-3
check /ip route print on Ros-3
[admin@Ros-3] > ip route print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
 0 ADo  10.1.12.0/24                       10.1.23.2               110
 1 ADC  10.1.13.0/24       10.1.13.3       ether1                    0
 2 ADC  10.1.23.0/24       10.1.23.3       ether2                    0
 3 ADo  10.10.10.10/32                     10.1.23.2               110
R3 can reach 10.10.10.10/32 from 10.1.23.2(R2)
/routing ospf area-border-router print on R3
[admin@Ros-3] > /routing ospf area-border-router print
 # AREA        ROUTERID        STATE      GATEWAY         COST
 0 backbone        2.2.2.2         intra-area 10.1.23.2       10
 1 backbone        3.3.3.3         intra-area                 0
 2 A13        1.1.1.1         intra-area 10.1.13.1       10
 3 A13        3.3.3.3         intra-area                 0
[admin@Ros-3] > /routing ospf lsa print detail  where id=10.10.10.10
 instance=default area=backbone type=summary-network id=10.10.10.10 originator=2.2.2.2 sequence-number=0x80000003 age=677 checksum=0x26F0 options="E" body=
     netmask=255.255.255.255
     metric=20
 instance=default area=A13 type=summary-network id=10.10.10.10 originator=1.1.1.1 sequence-number=0x80000003 age=676 checksum=0xDF45 options="E" body=
     metric=10
 instance=default area=A13 type=summary-network id=10.10.10.10 originator=3.3.3.3 sequence-number=0x80000003 age=542 checksum=0x6C9C options="E" body=
     metric=30
[admin@Ros-3] > /routing ospf lsa print detail  where id=1.1.1.1
 instance=default area=A13 type=router id=1.1.1.1 originator=1.1.1.1 sequence-number=0x80000005 age=1545 checksum=0x1FEB options="E" body=
     flags=BORDER
         link-type=Transit id=10.1.13.1 data=10.1.13.1 metric=10
and when Ros-3 <---->Ros-2 is down
 0 ADo  10.1.12.0/24                       10.1.13.1               110
 2 ADo  10.10.10.10/32                     10.1.13.1               110
R3 can reach 10.10.10.10/32 from 10.1.13.1(R1)
1.1.1.1 (Ros-1) is ABR? its should send a LSA-3?
Its unattached BackBone Area.
in RFC2328
        Area border routers
            A router that attaches to multiple areas.  Area border
            routers run multiple copies of the basic algorithm, one copy
            for each attached area. Area border routers condense the
            topological information of their attached areas for
            distribution to the backbone.  The backbone in turn
            distributes the information to the other areas.
It is a bug?
[admin@Ros-3] > system resource print
                   uptime: 3h1m40s
                  version: 6.36.4 (bugfix)
               build-time: Oct/05/2016 11:24:22
              free-memory: 75.9MiB
             total-memory: 96.1MiB
                      cpu: QEMU
                cpu-count: 1
            cpu-frequency: 2793MHz
                 cpu-load: 2%
           free-hdd-space: 69.6MiB
          total-hdd-space: 95.3MiB
  write-sect-since-reboot: 5320
         write-sect-total: 5321
        architecture-name: x86_64
               board-name: CHR
                 platform: MikroTik
