in the wireless registration table, once clicked on a registered client, what is the “P-Throughput” under the signal tab? is the the maximum throughput the link can withstand?
thanks.
thanks.
from manual:
p-throughput (read-only: integer) - (on station only) estimated approximate throughput that is
expected on the given link, by taking into account the effective transmit rate and hardware retries.
Calculated once in 5 seconds
Does this only work with MIPSBE?
I can’t get any readings on PowerPC routers.
P-Throughput works in wireless interface.
I can see it in mips-le, mips-be: I havent power-pc and x86 with radio.
I am getting P-throughput on on RB800 (PPC), but only on 802.11, not NV2 or Nstreme. RouterOS 4.17 (waiting for 5.3
