Here are what my System => Health readings are showing for my devices
The gears are in a room that i believe is room temperature so not sure why my readings are so high
- Are these values you get also?
- How do i change from C to F for the temperature reading?
CCR2004
CRS326
CRS312
Mikrotik being an European company default uses Celcius. I have not seen an option to set this to Farenheit just like am/pm in the time notation.
I see, yeah hope mikrotik fixes this as should be a very easy add
are those healthy temperature values?. what are you getting for yours?
These are not very high ones and the SPF could beover 80 celcius. Those with ether out can even go over 100 celcius…boiling water.
The temperature inside the rack reads 80/81 F
I have some rack fans that help also read temperature inside the racks
=> https://www.acinfinity.com/rack-fans/
just want to compare to others and make sure my devices are not running hot
Just got a sensor to measure the temperature of the server room also
so will be measuring the room temperature also for tracking
