what is the different between routing and routing-test pack?
Hi
I try to find the different between routing and routing-test package.
Already tried to find the thread in this forum but could not found it.
To run BGP on v3.25 or V3.26, which one is better? routing or routing-test package?
Thank you.
Aldhy SP
all new features and fixed are going only into the test package
Thank you normis :slight_smile:
So on v.3.25, it is better to use routing-test package right?
generally yes. also use v3.26
