What is the Dynamic servers of NTP-Client and how to set it?
AFAIK those are servers which the router gets via DHCP (option 42).
OK
If want it works.that has to get option 42 via dhcp server.
Is it right?
Yes, I assume. If you use a ROS device as your DHCP server, you have a dedicated field for the NTP server in your network entry under DHCP Server/Networks. On other systems, it varies.
I think if the DHCP server offers the option, the ROS client will use them automagically.
OK. Thank you docmarius !!!
I really appreciate your help very much.
I’m a bit late but you get that option when creating a dhcp-client. You need to check “use peer ntp”. Then, your ntp client will have the dynamic ntp server set.
Sent from my cell phone via Tapatalk. Sorry for the errors.
OK, Thank you.
