how can I update my “mAP 2n”?
when i run update from winbox I get
failure: there is no newer full release version available
can it be that the latest verion is 6.34.2?
Thanks ,
Thanks ,
It depends on the channel you are checking.
As of today the most current release is 6.37.3 for the stable channel, for the bug-fix-only channel the latest version is 6.36.4
In order to update you can always download the latest version from the Mikrotik website and upload the package to your routerboard.
I have try to downlaod
but I don’t have free space in the device…
so how can I upgrade?
Upgrade happens in RAM, you don’t need much free space
Install new ROS with netinstall. Beforce upgrade backup your config
Sent from my C6833 using Tapatalk
I want ot install v6.36
so I can copy only this file into the RAM ?
routeros-mipsbe-6.36.npk
Thanks ,
