Hi there
I am starting a wisp and i want use mANTbox 19s sectors. what is the throughput maximum will i expect and how many LHG can i connect to it.
Hi there
I sugest not to connect more than 30 cpe’s.
With 15 cpe traffic can go up tu 110mbps with NV2 in my case.
Uptime 241 days, so it’s stable.
hello Inox you have a good day. please can you recommend me that the team works better on the manbox19s. I read that with the sxtsq 5ac it is unstable. with which the client team can get the best performance? Thanks in advance
I’m use 19s with Lite5 AC CPE’s (no problems, all ok), one LHG 5 AC (for test purposes, results are bad, only work with newer beta firmware and still have poor nv2 perfomance. I not recommend it for production use). Also in test two SXTsq CPe, same problems like in LHG 5AC.
