What is the meaning of /setup r option?
Today I have bought a RouterBoard 750GL, and this is my first contact with Mikrotik products. I have used telnet to connect to router, and the first thing I tried is to use “reset all router configuration” option. The problem I am facing is. after executing this option, I am unable to access router anymore. DHCP service stops working, setting manually IP address in range 192.168.88.x doesn’t work also, WInBox is sensing a 0.0.0.0 IP address, but cannot connect to it. The only solution I found is to reset router using the reset button.
Why I cannot connect to router after /setup r, and what steps I need to take to be able to connect to it?
Also, I see that there is a new version of OS (5.:sunglasses:. How do I know if I am eligible to update the OS? When I bought this product, with it came RouterOS licence Level 4.
Thanks,
Goran
hai
when you reset mikrotik it lose all its addreses.so it do not contact with us.
In this situation we have one option that is login via MAC of mikrotik.it is possiable when sense in winbox it will display a line with MAC IP IDENTITY VERSION then just click on MAC addres.
Username is admin,it doesn’t have any password.then you can configure as you like…
Ah, the catch was, when using WinBox sense option, to click exactly on the MAC address, I thought it is irrelevant, and probably I was constantly clicking on the IP address.
Thanks.
