what is the optimum wireless configuration?
kindly find my Wireless configuration
 0  R name="MikroTik" mtu=1500 l2mtu=1600 mac-address=B8:69:F4:0B:4C:A9
      arp=enabled interface-type=Atheros AR9300 mode=ap-bridge ssid="MikroTik"
      frequency=2447 band=2ghz-b/g/n channel-width=20/40mhz-XX
      secondary-channel="" scan-list=default wireless-protocol=802.11
      vlan-mode=no-tag vlan-id=1 wds-mode=disabled wds-default-bridge=none
      wds-ignore-ssid=no bridge-mode=enabled default-authentication=yes
      default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0
      hide-ssid=no security-profile=default compression=no
i can achieve about 65Mbps
while i can achieve 100Mbps when using the wire
my Laptop Wireless intel Dual Band Wireless -AC 8265
and here is an image for the downloading
in addition to the below problem
23:55:14 wireless,debug MikroTik: F8:59:71:43:2C:18 attempts to associate
23:55:14 wireless,info F8:59:71:43:2C:18@MikroTik: reassociating
23:55:14 wireless,info F8:59:71:43:2C:18@MikroTik: disconnected, ok
23:55:14 wireless,debug MikroTik: F8:59:71:43:2C:18 not in local ACL, by default accept
23:55:14 wireless,info F8:59:71:43:2C:18@MikroTik: connected, signal strength -61
sep/10 00:04:35 wireless,debug MikroTik: F8:59:71:43:2C:18 attempts to associate
sep/10 00:04:35 wireless,info F8:59:71:43:2C:18@MikroTik: reassociating
sep/10 00:04:35 wireless,info F8:59:71:43:2C:18@MikroTik: disconnected, ok
sep/10 00:04:35 wireless,debug MikroTik: F8:59:71:43:2C:18 not in local ACL, by default accept
sep/10 00:04:35 wireless,info F8:59:71:43:2C:18@MikroTik: connected, signal strength -69
sep/10 00:12:56 wireless,debug MikroTik: F8:59:71:43:2C:18 attempts to associate
sep/10 00:12:56 wireless,info F8:59:71:43:2C:18@MikroTik: reassociating
sep/10 00:12:56 wireless,info F8:59:71:43:2C:18@MikroTik: disconnected, ok
sep/10 00:12:56 wireless,debug MikroTik: F8:59:71:43:2C:18 not in local ACL, by default accept
sep/10 00:12:56 wireless,info F8:59:71:43:2C:18@MikroTik: connected, signal strength -64
sep/10 00:12:58 wireless,debug MikroTik: F8:59:71:43:2C:18 attempts to associate
sep/10 00:12:58 wireless,info F8:59:71:43:2C:18@MikroTik: reassociating
sep/10 00:12:58 wireless,info F8:59:71:43:2C:18@MikroTik: disconnected, ok
sep/10 00:12:58 wireless,debug MikroTik: F8:59:71:43:2C:18 not in local ACL, by default accept
sep/10 00:12:58 wireless,info F8:59:71:43:2C:18@MikroTik: connected, signal strength -65
sep/10 00:13:56 wireless,debug MikroTik: F8:59:71:43:2C:18 attempts to associate
sep/10 00:13:56 wireless,info F8:59:71:43:2C:18@MikroTik: reassociating
sep/10 00:13:56 wireless,info F8:59:71:43:2C:18@MikroTik: disconnected, ok
sep/10 00:13:56 wireless,debug MikroTik: F8:59:71:43:2C:18 not in local ACL, by default accept
sep/10 00:13:56 wireless,info F8:59:71:43:2C:18@MikroTik: connected, signal strength -56
sep/10 00:13:59 wireless,debug MikroTik: F8:59:71:43:2C:18 attempts to associate
sep/10 00:13:59 wireless,info F8:59:71:43:2C:18@MikroTik: reassociating
sep/10 00:13:59 wireless,info F8:59:71:43:2C:18@MikroTik: disconnected, ok
sep/10 00:13:59 wireless,debug MikroTik: F8:59:71:43:2C:18 not in local ACL, by default accept
sep/10 00:13:59 wireless,info F8:59:71:43:2C:18@MikroTik: connected, signal strength -60
sep/10 00:14:05 wireless,info B4:C4:FC:5E:78:36@MikroTik: disconnected, received deauth: sending station leaving (3)
any help please
get rid of band=b. Channel-width=20/40mhz-XX depending of the distance
i did
it’s not helping
What speeds do you expect to reach ? For me, you need to fix - channel-width=20/40mhz-Ce frequency-mode=superchannel installation=indoor !
After all, it all depends on whether there is radio interference and how strong it is!
Have a look at this MUM presentation on improving Wifi speeds. Limiting the available rates can help.
https://mum.mikrotik.com/presentations/EU18/presentation_5155_1523286214.pdf
i will try what you suggest
but i expect stable connection with high speed 80 90 mbps
as i’m 2m far away from Wireless router
You could try reducing tx-power and setting tx-power-mode=all-rates-fixed
to see if that improves the connection ( bear in mind, it will also reduce coverage )
There is only two values for Wi-Fi optimization and router peak boost performance I found out over the years of RnD.
  1. Set Wi-Fi Region to USA for full RX/TX power output :slight_smile:
  2. Set MTU from 1500 to 1452 for all the interfaces then reboot device it will be heaven there after!
One more thing to note as many mess with the default IP Settings values and end up worst performance… please leave it at Default value!
/IP Settings, UnCheck = Accept Redirects, UnCheck = Accept Source Route, UnCheck = TCP SyncCookies
Good RnD and have fun!
Rodney Yeo
http://rodyeo.dyndns.org
Malaysia
