What is the problem the following script?
:for i from=1 to=1500 do={ /tool user-manager log remove number=$i; }
run but no delete log file
usermanager v4.17
usermanager v4.17
Do you want to delete only logs 1-1500? Or all of them?
If you want to delete all the logs, do:
/tool user-manager log remove [find];
you can check the output of [find] and see what numbers are expected there.
your initial script would work if you did print before remove. That would add temporary numbering that is assigned when print is done.
After doing the print command, how long are the numbers associated with the items? Is there a timeout of some kind, or how does that work?
