Hello all i am trying to upgrade my distribution backhaul fiber network to 10g, so i want to use CRS305-1G-4S+IN as my drop point at outdoor NOC, my current traffic 3gbps can CRS305-1G-4S+IN handle 5gbps or more just using vlan in switch os mode any real user review will be great.
Ethernet test results
CRS305-1G-4S+IN 98DX3236 all port test
Mode Configuration 1518 byte 512 byte 64 byte
kpps Mbps kpps Mbps kpps Mbps
Bridging none (fast path) 104,3 1266.6 273,5 1120.3 449 229.9
Bridging 25 bridge filter rules 104 1263.0 104,6 428.4 104,5 53.5
Routing none (fast path) 104,3 1266.6 273,9 1121.9 343,5 175.9
Routing 25 simple queues 104,3 1266.6 136,9 560.7 137,4 70.3
Routing 25 ip filter rules 64,8 786.9 65,9 269.9 65,8 33.7
Source : https://mikrotik.com/product/crs305_1g_4s_in#fndtn-testresults
I would say about 270 Mbit/s
CRS305 used as a switch can do wirespeed. Even if running ROS.
CRS305 used as a router does what @zacharias wrote - around 270Mbps.
So can i expect 5g throughout at switch mode with just vlan config
Yes, assuming you don’t do the inter-VLAN routing on it. Traffic that stays within a VLAN will be switched at wirespeed.
