what is the total bandwidth of bridge
hi,
a simple question what is the total bandwidth bridge can pass i:e total of physical interfaces
for example I’d got a bridge ether3 and ether4 on ccr. So total bandwidth should be 2gbps or 1gbps. As I’m seeing my total bandwidth doesnt go above 1gbps even if the traffic is on both the ports and going to internet on ether1(wan).
thanks
Bridging is done in cpu so actual cpu utilisation together with the available link capacity between the ports and cpu matters all together.
thanks, true I’ll have to check y total bandwidth on bridge is limited to 950mbs where as traffic is coming from 2 x 1g port on bridge and going out to 2 isp on different 1g ports.
