What is this What does it mean
What is this
What does it mean
No refund
Apparently, you’ve enabled logging for your web proxy, and you’re just seeing the URLs that were accessed via it. Everything in this log, including the part you’re showing is just that…
Or are you asking about something more specific? What?
Your webproxy has not found the file in the cache so it needed to be downloaded.
Yes, thank you
Answer
I think you’re just as well
But webproxy file exists in the files
What is the solution in your view
Dear sir
I never had reason to use webproxy. I would advise you to switch it off or switch off logging of this event or just neglect it because it doesn’t look to me as an error.
How can I blowing
Simply blow whenever you want.
