Is there any body can tell the maximum coverage distance for 90degree RBSXTG-5HPnD-SAr2? and is it possible to use backhaul direct ethernet from the device to grooveA-52HPn?
I will appreciate if I can getnpractical advice of this device and configuration, at bandwidth above 10Mbps.
Ok thanks for your concern, I think the best way I have one for test then I will get answer for some questions, then from there we can share the results.
