What MikroTik solution works for a home multiple 5G repeater Wifi network
Hi Folks,
I need to deploy a few (4-5 in total) 5G wifi repeaters in a house so that it will have pretty good 5G coverage anywhere in the house.
The problem is that most wireless based Wifi repeater can only provide 2.4G connectivity to clients.
Can someone suggest a solution that would give all repeaters the same 5G connectivity and allow a wifi client to roam around it? I suppose the solution will be something like one router with cables connect to each repeater, but just don’t know what MikroTik products I should look into, thanks for the help!
Regards
David
Check out their new Audience lineup… (mesh of some sort)
+1 for the audience.. also it does not do repeating so you will not have any loss in bandwidth…
