What routerboard can connect a 3G USB modem
Hello:
I have a routerboard RB751U-2HnD that has a USB port that can connect a 3G USB modem.
What other models can connect a 3G USB modem?.
Regards
you can check routerboard.com for other routers that have USB port.
All models with USB connector USB 3G modem support?
regards
yes, that is the case.
However for ease of use you can look up USB with power-reset feature, so you do not have to unplug the dongle if it hangs. As some USB dongles does that.
ebe: Not all models support USB modems out of the box. e.g. RB4xx series needs external power on USB port (there is a way to bypass it, but it voids warranty). You should check models like RB751U, RB951U, etc. depends on what you are looking for (CPU performance, port speed, design?,…)
edit:
I have good experience with RB751U routers with ZTE 668(a) USB modems, but it supports 3G max.
