What RouterBoard is Suitable for 11N ???
Hi all..
I just tested the RB433 with R52N by Using 5Ghz…
When i do the speed test from “Pc 1” to (RB433+R52N <=>RB433+R52N) “PC 2” …
I found that, The CPU Load of the RB433, when it up to 62% ~ 75%, then the connection speed cannot go higher.
The RB433 is only able to Give 70Mbps in + 70Mbps out at the same time with 20~30ms ping times.
What is the Best RouterBoard for the R52N???
And, any optical interface can be use for RouterBoard?
