what setting is need to know the distance between two sets
Please can anyone hlep me.
I used RB435G board and R52Hn card with a 28db solid dish for point to point
I think the distance is within 40 km, but i want to know the exact distance of my two set.
I set the tranmiter at Station wds mode and the receiving sectors at Bridge mode. The signal strenght is -77 and i got 90mbps speed
I’m not a trained person…waiting for your reply…ty
if the channel width is 20Mhz…
then it’s simple and straight forward…
login to the CPE unit, go to wireless > wlan1 > status > then u can see it…
Somehow it only reports the distance in 802.11 or nv2 mode and not in nstreme. Keep that in mind.
ok…i can get the distance with your help
Thank you so much guys
thank you guys.
now you solved my problem
thank you guys
because of your sugestion, my problem was solved
thank you so much :slight_smile:
