See below the attached screenshot.
thx in advance.
what is the question exactly? you turned on webproxy debug logs.
Why i am getting that webproxydebug err msg in my logging? Is this error log? that means there is something wrong with my webproxy configuration? or i shouldn’t worry about it?
thx
Like Normis say, you enabled the logging for webproxy.
Disable it from System > Logging.
M.
That i can figure out myself lol, heheh, i know that i enabled. Read my question.
thx thou
There is no error shown. Just a debug message. Your question is unclear and ambiguous. Restate it quoting the exact system output that is confusing to you.
thx fewe
so debug is not an error.
Hard to believe it, looking at it from commuter programmer point of view. I will keep that in mind. from now on. Screen shot should say enough, doesn’t?
thx thou
Those are syslog levels, as common across all kinds of systems. If you read http://en.wikipedia.org/wiki/Syslog you can see debug is the highest available level, and includes things like notice and info - it’s not just errors, it’s ALL messages output by a program, including those for debugging the program (“I am now going to start something!”, “I started something”, “I completed that something without errors”).
What your screenshot is showing is the proxy process proxying things for people during normal operations.
FEW YOU ARE THE MAN,
thanks a lot.
IF WIKI COULD JUST JUST AS SIMPLE AND AS STRAIGHT TO THE POINT WHAT IT REALY DOES IN BIG PICTURE. OUR LIFE WOULD BE EASIER.
THXX example you gave were more than i could expected, thanks man,
P.S
To find ex. USB plug in pc, is good to know where to find PC. lol. Conman sens, and logic is the universal key that leads the humanity, thx all.
RouterOS is for network administrators. You should know some computer basics. Our documentation doesn’t have basics, like how to turn on Windows, or how to use a mouse.
I know, working on improvements lol
