What tpye 108M wireless network card can support by MT ?
I check it in hardware list, just found the 11M wireless card to support.
Any one could tell me the tpye you used in MT?
TP-Link TL-WN651G 108Mbps
http://www.tp-link.com/products/product_des.asp?id=17
I get arround 5.5MB/s ( 44Mbps ) of real speed.
Note: you need to put card in G-Turbo!
how many access point can connect to this card in the same time
ummm you mean clients? i have tested 20 and it works ok but slightly reduced speed… cca 5MB/s (arround 40mbps)
If you want full PCI the Airlink101 108Mb card works well.
If you want MiniPCI give the R52 a try..
Both work well under RouterOS…
You could use a R52 in a MiniPCI to PCI adapter, but the Airlink101 can be piced up on http://www.frys.com on sale for under $20.00 US.
Craig
I bought a TP-LINK 650 PCI wireless card
It work normal in MT.
I have successfully setup SMC 108mbit wifi card, but it does not run at 108Mbit, only at 54mbit, seems MT only supports 54Mbit, not sure though.
The TP-LINK 108mbit also has atheros chipset and works
Also any card using atheros chipset should work, as long as you are using a PIII or above as older boards do not support PCIv2
Voltage issues.
Hope that answers your query
use turbo. also 108Mbit doesn’t mean it will actually run at this speed
please note, that air rate and data rate are not the same value if talking about wireless
