What version of MikroTik do you use?
- 2.9.12
- 2.8.28
- Other?
This is a poll… so what version do you use? and why?
I always like to use latest software. A lot of ppl are experiencing problems updateing their routers without loosing configs. This is bad. MT Team: keep up the good work… fix those problems, add those features… ![]()
You will no loose any configs… only if you upgrade from 2.8.X to 2.9.X you have to check some configs, export them, and then put it again on MT
You dont tell what version do you use… 2.7.x ? ![]()
Regards
I just cannot answer the poll easily…
Mostly current 2.9 versions of course, but there are 2.8.28, and I even stumbled over a running 2.5.x some weeks ago ![]()
Best regards,
Christian Meis
I use 2.8 exclusively,once a router is set into production it makes little sense to update for the sake of updating–
I will update when the licensure is get close to expiring to get the most recent P2P protocols.
That said, there are times to update in order to get new features.
I am however, ready to play around with 2.9 as it seems most of the bugs are being addresssed…
FWIW, Hugh
heh…
Hard question, because i have all sort or versions from 2.2 to 2.9.12 ![]()
I am using 2.7 and I am happy ![]()
Why fix if nothing is broken…
why? first - you cant get support or help from forums ![]()
I would like to see 2.9.13 in this list ![]()
I used 2.8.28, but after reading replyes about 2.9.12 i installed it on all routers…works great…bandwich test on one link from ap to client router show 56.4 mbps (protocol tcp, direction send).Nstreme enabled, frame policy dynamic size, 2.4g-turbo, about 3 km).On 2.8.28 with same config bandwich was 32 mbps, but without nstreme.
i know what you mean, but let others wait 30 seconds and they will be able to download it as well
My home unit is now 2.9.13.
In our network there are a few dozen different versions, I would love to standardise, but that will be a major task. With new versions coming out as often as they do, I don’t think it would be possable to complete an upgrade, before the next version (or 2) came out.
We did manage to get rid of 2.7.x completely, but we still have some 2.8 betas floating around.
–Eric
Why worry about support if all works ![]()
Of course, there are many new features in latest versions, but they are not critical for my network, so… MT should be proud if older versions are so stable and can work for years without patching and upgrading.
Ooops, double post ![]()
I`m on 2.9.8 just becouse the upgrade licence has expired
Will update it soon, and go to the latest version…
I use MT to split internet into my LAN. My lan consist of 4 computers connected by UTP, and one connected with wireless (Atheros Sparklan). My connection to internet is realised also by air (Atheros 5211). I have a small www, ftp, mail, mrtg server in my lan. I use forwarding, dhcp, queueing, scripting - rather basic functions. Could You help me with decision - is there any idea to upgrade from 2.8.26 to the newest version?
Thanks in advance.
FYI–upgraded one of my test units (transparent bridge configuration)to 2.9.13 from 2.8.28 without a hitch–
MANGLE and QUEUE TREE not working as documented by MT, but to my surprise: Simple queues, custom queue types and Firewall chains all working.
Thank You for information. This is rather good news.
