What wrong with script
:if ([/ping 8.8.8.8 count=5] = 0)
do={
	:log info ("WatchDog connection Failed");
	/interface ppp-client disable 3g-intertelecom-1;
	:delay 5s;
	/interface ppp-client enable 3g-intertelecom-1;
		do={
		/system reboot;
else={
	:log info ("WatchDog connection OK");
Won’t work ((( something wrong with syntaxes here but i can’t understand exactly what is it?
:if(definition) {do={} else={}} or how ? command; or how?
try this:
:if ([/ping 8.8.8.8 count=5]=0) do={
   :delay 5s;
      do={
      /system reboot;
else={
its
:if(definition) do={} else={}
or in above case
:if(definition) do={ :if(definition) do={} else={} } else={}
Seems to not working…
It not says to log ok or failed…
How to check right syntax is any debug or something like that … I can’t understand what’s wrong with it…
Logic is
Ping some address if failed disable ppp connection and with 5sec delay re-enable it…
Try again ping if still failed do router reboot…
If ping goes nothing to-do…
ROS 5.8 RB751-2nHD
I find that scripting is sensitive to the placement of do and else.
It seems best to put them on the same line as the “if” and closing “}”
   :delay 5s;
   :if ([/ping 8.8.8.8 count=5] = 0) do={
      /system reboot;
} else={
If you run the script from the console you can see where the error is occuring:
/system script run <your script name>
something wrong with 3 row …
Ok i understand “name_of_connetion”
now it’s working
