What's a good replacement / upgade?
Right now I have a RouterBOARD 3011UiAS, which has worked awesome.
It however doesn’t have the 1+Gbps capabilities I want to have for the future.
I want to be able to bond two or more WAN ports from a cable modem (2 to 4 max) to get the over 1Gbps speed offered on comcast now, they max out at 1240Mbps so 2 ports bonded right now would work). When I do LACP bonding right now on my current one the speed slows down to about 300Mbps, unbond them and I get 900Mbps.. so I am guessing there is hardware limitation there.
My goal would be to have a bond from my router to the switch or use a 10G SFP+ connection between the two, then have a bonded copper port connection to the cable model.
I was looking at a CCR1009-7G-1C-1S+, but not sure if that is enough, too much, etc..
what would you recommend? or am I doing something wrong on my 3011UiAS?
I think the RB4011iGS+RM should be able to do this.
If I bond two copper 1Gbps ports on that model would it use hardware offloading or would it all be done at the software / CPU level? I’m kind of thinking that’s why I see a big drop when bonding now is I am not getting the hardware acceleration, nor am I sure how to verify that I am or am not on the bond
I also have multiple VLAN’s it appears (maybe I am wrong) but this model’s chipset doesn’t support VLAN’s at the hardware level so it will offload to the CPU for handling?
The next level of 3011 is 4011, but if you want more power, next is 1100ahx4. Next, some CCR.
Regards.
Which ports are you doing the bonding on?
There are two switch chips in the 4011’s. One for ether1-5 another for ether 6-10
Ports 1 and 2, I assumed you want to bond on the same switch chip, maybe that's not the case? Not sure I read the block diagrams right, there is only 1Gbps per switch chip back to the CPU, so to get 2Gbps (max theoretical) I would have to be on two switch chips or on just one? or should I bond on one switch chip and put the LAN on another?
AFAIK bonding is done in software (except for CRS3xx), so all the traffic will pass the switch chip - CPU interconnection. RB4011 features a 2.5Gbps interconnection link, so theoretically it should be possible to exceed 1Gbps over a bond regardless which ports are in bond (but traffic will fight with the rest of traffic, e.g. LAN-CPU traffic). If both links are using same switch chip, the will almost saturate the interconnection though.
The problem is even bigger on RB3011 with its dual-1Gbps interconnects (one per CPU core) … I highly doubt a single bond scales nicely over both CPU cores, only Buddha knows how’s interconnection between both cores. In case of RB3011 bonding ports from both switch chips might help … if traffic from those ports really get routed to the same CPU core … and, again, only Buddha knows how switch chips determine which CPU connection to use for delivery of particular packet … I guess the chances for that are fair given use of some advanced features of Qualcomm switch chips in ROS.
