I have an old Mikrotik routerboard and a 1500 sqft house - should I replace the router or add a wifi 6 access point? Which access point should I get, and can I get away with just one? Is it worth it to spend over $300 to upgrade to a full Ubiquiti setup, and if so, what router and access point combo do you recommend?
