what's the first hop in this traceroute?
hi guys
anyone can tell me how can I find out what’s the first hop with ip address 0.0.0.0?
I have this thing when I ping almost anywhere
thanks
[admin@PersiaRestaurant] > tool traceroute www.time.net.my
     ADDRESS                                    STATUS
   1 0.0.0.0         timeout timeout timeout
   2 219.93.218.177  98ms 96ms 86ms
   3 219.93.216.21   16ms 15ms 16ms
   4 210.187.129.139 16ms 16ms 16ms
   5 210.187.15.253  17ms 17ms 17ms
   6 210.187.142.1   17ms 17ms 17ms
   7 219.93.151.104  208ms 316ms 396ms
   8 202.71.100.9    17ms 18ms 17ms
   9 218.100.18.17   19ms 18ms 19ms
  10 218.100.18.10   20ms 20ms 20ms
  11 211.25.28.9     20ms 19ms 20ms
  12 203.121.64.206  19ms 19ms 20ms
it should be the IP of your gateway… i’m guessing it doesn’t respond to that type of ICMP request (tracert uses a different ICMP request then ICMP Echo to discover the route)… try allowing all ICMP and see what that does.
the thing is I have not blocked anything and there is no other node to my knowledge in the path…
is 219.93.218.177 the default gateway for your router?
If you have a Windows PC, get R1CH’s ftrace and run it with -u to use UDP instead of ICMP.
