I simply wanted to block port 25.
So I placed the rules as given by Microtik support, but there is absolutely 0 traffic hitting, while I can clearly see the wan port and lan port getting all spammers traffic.
Attached is the screenshot of the firewall rule and torch of wan to show that, the rule doesnt work which the microtik support had given me.
Change the chain to “Input”, Forward only blocks traffic passing through the router. If you want to stop from sending email (port 25) from inside your network, change the chain to “Output” which will block all port 25 going out the wan port. Also make sure you specify which interface for input and output (in your case it looks like you are using an SFP port for your WAN connection, but i can’t be 100% sure without looking at your whole config.
Also i see you have an accept rule for port 25, and a block rule for port 25, If you want to block port 25 completley, put the block rule above the accept rule (or disable the accept rule all together).
From looking at the torch screenshot I assume soamz is definitely routing some public subnets.
I have to contradict your statement, mlpaul. the forward chain is exactly the rule to apply. Input chain catches all connections terminating in the router, output chain covers all connections originiated by the router itself. In this case, soamz is routing at least one public subnet through another public network.
I don’t see any errors in your screenshots.
mlpauls is right that the accept rule would be counterproductive when you want to drop the traffic.
But nevertheless, the counters should show anything but zero.
Looking at your SIP drop rules at the bottom proves that the firewall is working.
So there must be something wrong with you rules - and WinBox doesn’t show all parameters of a rule in the list view.
Could you post an export of your firewall rule set?
/ip firewall filter export
And, if possible, your interfaces and IP-addresses (so that we know which networks you serve)
This could help us figuring out what’s going wrong.
-Chris
If 103.75.41.217 is your customer, you’re not looking at smtp traffic to them, it’s traffic from them to many remote mail servers. So either they went into spamming business or got hacked or something.
