Hello!
[boris@MikroTik] > /routing bgp instance print
Flags: * - default, X - disabled
0 * name=“default” as=198070 router-id=31.44.12.205 redistribute-connected=yes
redistribute-static=yes redistribute-rip=no redistribute-ospf=no
redistribute-other-bgp=no out-filter=rm-bgp-local
client-to-client-reflection=no ignore-as-path-len=no routing-table=“”
/routing filter
remove [find chain=rm-bgp-local]
add chain=rm-bgp-local action=passthrough protocol=“connect,static” address-family=ip set-bgp-local-pref=900 set-bgp-communities=“local-as,65070:100”
add chain=rm-bgp-local action=passthrough protocol=“connect,static” address-family=ipv6 set-bgp-local-pref=900 set-bgp-communities=“local-as,65070:100”
add chain=rm-bgp-local action=passthrough protocol=“static” address-family=ip prefix=31.44.12.0/23 set-bgp-local-pref=900 set-bgp-communities=“65070:101”
add chain=rm-bgp-local action=passthrough protocol=“static” address-family=ip prefix=89.223.20.0/24 set-bgp-local-pref=900 set-bgp-communities=“65070:101”
add chain=rm-bgp-local action=passthrough protocol=“static” address-family=ipv6 prefix=2a00:ff20:0001::/48 set-bgp-local-pref=900 set-bgp-communities=“65070:101”
/routing filter
remove [find chain=rm-bgpv4-upstream-out]
add chain=rm-bgpv4-upstream-out action=accept address-family=ip prefix=0.0.0.0/0 prefix-length=8-24 bgp-communities=65070:101
add chain=rm-bgpv4-upstream-out action=accept address-family=ip prefix=0.0.0.0/0 prefix-length=8-24 bgp-communities=65070:104
add chain=rm-bgpv4-upstream-out action=discard
[boris@MikroTik] > /routing bgp peer print detail where name=up-v4-comfortel
Flags: X - disabled, E - established
0 E name=“up-v4-comfortel” instance=default remote-address=85.143.187.21
remote-as=56534 tcp-md5-key=“” nexthop-choice=default multihop=no
route-reflect=no hold-time=3m ttl=default in-filter=rm-bgpv4-upstream-in
out-filter=rm-bgpv4-upstream-out address-families=ip default-originate=never
remove-private-as=no as-override=no passive=no use-bfd=no
[boris@MikroTik] > /routing bgp advertisements print up-v4-comfortel
PEER PREFIX NEXTHOP AS-PATH ORIGIN LOCAL-PREF
up-v4… 85.143.188.0/23 85.143.187.22 51783,51783,5… igp
up-v4… 83.96.23.0/24 85.143.187.22 35000,20764,2… igp
up-v4… 37.237.194.0/24 85.143.187.22 35000,20764,1… igp
up-v4… 93.95.26.0/24 85.143.187.22 35000,20485,1… igp
up-v4… 85.9.104.0/21 85.143.187.22 35000,20764,2… igp
up-v4… 85.143.168.0/22 85.143.187.22 51783,51783,5… igp
up-v4… 37.238.158.0/23 85.143.187.22 35000,20764,1… igp
up-v4… 85.143.187.22 35000,20764,2… igp
up-v4… 151.236.161.0/24 85.143.187.22 35000,20764,2… igp
and all 600k prefixes more
For example:
[boris@MikroTik] > /ip route print detail where dst-address=2.189.48.0/22
0 ADb dst-address=2.189.48.0/22 gateway=85.235.198.125
gateway-status=85.235.198.125 reachable via VL0.230 distance=20 scope=40
target-scope=10 bgp-as-path=“35000,20764,200612,12880,49100,34918”
bgp-local-pref=200 bgp-origin=igp
bgp-communities=0:0,20764:3000,20764:3013,20764:3020,20764:3031,35000:1105,
65070:102
received-from=up-v4-prometey
1 Db dst-address=2.189.48.0/22 gateway=85.143.187.21
gateway-status=85.143.187.21 reachable via VL0.1605 distance=20 scope=40
target-scope=10 bgp-as-path=“56534,20764,200612,12880,49100,34918”
bgp-local-pref=200 bgp-origin=incomplete
bgp-communities=0:0,0:6412,0:12880,0:15802,0:43852,0:48159,0:48728,0:60929,
5607:5607,8714:8714,20764:3006,20764:3014,20764:3020,20764:3035,
56534:1000,56534:1040,65070:102
received-from=up-v4-comfortel
May be I’m ver very stupid. But please tell me, why the route 2.198.48.0/22 for example is announced to upstream???
Regards,
Boris
