i use DOM for system n HDD slave for cache
this is my setting
MAIN ROUTE] /ip proxy> pr
enabled: yes
src-address: 0.0.0.0
port: 8880
parent-proxy: 202.xxx.xx.xx
parent-proxy-port: 3128
cache-drive: system
cache-administrator: “webmaster”
max-cache-size: 165000KiB
cache-on-disk: yes
max-client-connections: 5000
max-server-connections: 5000
max-fresh-time: 3d
serialize-connections: no
always-from-cache: yes
cache-hit-dscp: 4
what i wanna ask is :
- why my web proxy has no hit
status: running
uptime: 1d2h36m38s
requests: 94141
hits: 0
cache-used: 0KiB
total-ram-used: 1821KiB
received-from-servers: 1134266KiB
sent-to-clients: 1120036KiB
hits-sent-to-clients: 0KiB
can i make a mikrotik web proxy for multiple parent proxy ?
can i make a mikrotik web proxy for sibling proxy to another proxy
regards
baba
ip
firewall
nat
dst nat
destination protolocol 80
action
redirect your web proxy port
rboerom, can you see
alienux
maybe some rules in WebProxy → Cache or WebProxy → Direct?
i already doin that
chain=dstnat action=dst-nat to-addresses=202.xx.xxx.xx ( my own ip that allowed for access to parent proxy ) to-ports=8880 src-address-list=proxy dst-address-list=!nice dst-port=80 protocol=tcp
i dunno whe i used with out parent my proxy can cache to local disk.. but when i do a parenting can’t cache anything
Your proxy runs on the system drive according your print.
I tried webproxy as well on my system drive and also get no hits.
Somebody informed by webproxy does not work on the system disk.
I have to make new system with separate disk for the webproxy cache.
Or, anybody has other idea?
Rudy
