Hi all,
After making an attempt to add a dhcp-server on a wifi interface, as below, the dhcp-server is flagged as “invalid”:
NAME INTERFACE RELAY ADDRESS-POOL LEASE-TIME ADD-ARP
0 I server1 ether3 dhcp-eth3 3d yes
1 I dhcp-public wlan-g-public public-pool 1h yes
Is there a way to find a reason string anywhere or error message to give a hint as to why the entry is invalid?
I tried /log print to see if anything was logged, but nothing showed up.
Regards,
Graham
do you have an IP address on that wifi?
Yes:
3 172.16.250.3/23 172.16.250.3 172.16.250.3 wlan-g-public
It doesn’t answer why no reason is given for the error. Is there is way to get some kind of human readable error message out of this?
no (sure, yes - you can write to support
). try to set ‘src-address’ for your dhcp server
by the way, your server on ether3 is also invalid…
What I am really trying to do is try set up a hotspot, it is not clear from the documentation whether you need to configure a dhcp server to be used by a hotspot, or whether the hotspot does this on its own.
The attempt to create a hotspot using the hotspot setup wizard also results in a hotspot that is listed as “invalid”, again with no error message, hint or clue as to what the problem might be. I can see nothing obvious in the config that looks wrong, but then as this is the first hotspot I am trying to set up, that doesn’t mean much. Without error messages, new users are left marooned.
The hotspot config looks like this:
Flags: X - disabled, I - invalid, S - HTTPS
0 I name=“hotspot1” interface=wlan-g-public address-pool=hs-pool-1 profile=hotspot-public idle-timeout=5m
keepalive-timeout=none addresses-per-mac=2
The interface looks like this:
Flags: X - disabled, R - running, D - dynamic, S - slave
0 name=“wlan-g-public” mtu=1500 type=“wlan”
I understand the interface only lists itself as “running” after a single user has connected, could this be related?
yes, if the interface isnt running then it will be invalid. same with the dhcp server.
Sam
