when ROS's handware supported 10GB?
does ROS bate 4.* supported 10GB now?
I have some inter PCI-E 10Gb fiber cards,the ROS v 3.* resources PCI device can search the 10GB card,but interfaces does not print the 10GB card,does not support,or will support in bate v5.*?
There are few cards supported by the RouterOS with such rate. Which company is the manufacturer of your card?
inter CB82597EX,I test again with 5.20,interface has nothing,the rescource PCI’s list has it.
