When set to Auto PoE, conduction expires suddenly
Hello, all
It may be just my environment, but he can not be used with PoE power supply, the RB260GS and RB912UAG by using RB260GSP, but this is set to automatic only Port4 and Port2 for some reason, continuity off suddenly one day it encounters a phenomenon I put it away.
Problem in Port3, Port5 's not occurred so far, but because in fact this problem has also occurred twice so far, and he was replaced with RB260GSP spare, but does not improve the symptoms.
Will no one similar symptoms has occurred in you?
Verification environment:
RB260GSP (SwOS1.12)
Best regards.
