hi guys…
i have a sxt lite5 (5nD) that work good but when unplug power cable and turn on again all config reset factory.
i used netinstall with several version but problem not solved.
I think the hardware problem.
please guide me.
have the same problem with my gr3 ![]()
I get that here once in a while with sxt’s, usually caused by water. Dry it out, clean the reset pads and everything along that circuit trace. If it has a reset button, check it with an ohm meter. Have used clear nail polish to protect the traces after fixing the problem (make sure that it is not conductive).
Sent from my SM-A520W using Tapatalk
