Hi, I've just bought a new Mikrotik hAP be³ media, and I saw that it doesn't support MicroSD cards yet. Is there an estimate to when will it be supported?
Thank you!
Thank you!
Thin that not soon as it is the very fresh product, just sent to distributors, and it would need a new motherboard for SD card.
If you can sacrifice one USB port then I suggest:
I think only software support is missing.
That's why there is a paper in the device package SD support is coming with a next ROS version.
But which version ? That only Mikrotik knows ...
Have you tried alfa build 7.25: https://mt.lv/nightly-build ?
According to this Hap be3 Media CPU temperature - #7 by klayf the main question is: where to place the SD socket to not let the SD card be toasted?
@BartoszP
There is ALREADY a slot for microSD card, on top, near the USB sockets, only there is not software support (yet).
What s point to sell half cooked product with SD Card slot, but without SD card software support? Is Mikrotik a, new Apple with their "Apple Ai" that was supposed to come in their new software updates. Lol
better release it with a SD Card Slot that will be supported later than postpone the device for X more months ![]()
(or to remove it like with some CCRs)
It landed.
Now we're just waiting for the Long-term RouterOS release
....in about 4 months from now. Happy waiting!
