I have tried almost every combination of install with very poor results.
I hope that the RB133 will work with the BETA’s soon.
hytanium i ve spend my weekend for this ; but returned to 2.9 ; ppl say the only diffrence is pseudo bridge ; i read some ppl who succed over the form; try it out with search..
I had good results using the SR9 with the early Beta 3’s. I was using the RB112 but the Rb133c, I have yet to get working sucessfully.
I have managed to get it working without NTP and wireless… not much use to me as a CPE without the wireless ;.)
I will have to wait.
i did a buch of testing trying to get beta 10 to load on a 112, ended up only getting it to work reliably without wireless (NTP was never loaded in my tests)… time after time, load wireless, system hangs forcing netinstall to re-load…
New version of 3.0 should work fine with RB133c.
Disable all wireless interfaces and reset-configuration to defaults before upgrading.
Also be patient after the reboot.
This does in fact work on the 133c
